Home > General & Technical (L663) > Auto lights - switching off when they shouldn't?
Page 2 of 2 <12
LR Nuts
LR Nuts wrote:
.......I have a spare pair of the LED rear lamps for the L663, they are more difficult as everything is enclosed and sealed. It might be easier to drill the rear DRLs in the fog lamp cluster, although these are lower level lamps than I would like. I have a spare set of those also. Time to go in the workshop and play Very Happy
Been at the bench today and worked out the wiring to give REAR DRLs. I have them working. You will need to have trained in gynaecology to get at the two wires needed, after drilling into the red plastic upper filter. NOT a job for the faint-hearted.
There are 5 connections of the interlink cable between the Main PCB (larger one) and the Secondly PCB (smaller one).
Two wires need to be cut and joined together with a third lead, which will then connect to an ignition positive feed from the boot fuse box.
I have only done this test on a spare lamp cluster. Will do the clusters on my vehicle when I get the time. Then I will take step-by-step photos.
It's the lower two of the black wires that need cut.
This gives you Rear DRLs
Then DRLs plus sidelamps.
Remember when ignition is 'on' so will the DRLs be 'on', when ignition is 'off' you ONLY get side lamps on larger lamps.
I may fit a relay so when ignition 'off', ALL rear side lamps are 'on', when they should be.
Post #1008833 25th Sep 2023 5:38pm
Moo
Ukraine
That's impressive. Really keen to do this. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1008835 25th Sep 2023 5:47pm
Retroanaconda
Can’t you just put your lights on manually in those situations where the automatic function isn’t appropriate?
Post #1008841 25th Sep 2023 6:12pm
LR Nuts
sadly not.
LR decided what they, not the customer, thought was wise.
Post #1008852 25th Sep 2023 7:49pm
Retroanaconda
I don’t understand, why not?
Just today I turned my lights on manually as I was in mist and then low sunlight. They stayed on for the whole journey, and don’t switch off automatically.
Post #1008854 25th Sep 2023 8:01pm
I abhor the current trend to make it impossible to drive with sidelights and not headlights, and have trouble understanding how even a moron can think it is a good idea.
It is, for example, illegal to have your headlights on whilst reversing and yet it is no longer possible to reverse at night legally. Not to mention that if you regularly drive on single track roads where reversing significant distances due to oncoming vehicles is a frequent occurrence, reversing with your headlight blazing at the vehicle you are giving way to is both inconsiderate and offensive.
Unfortunately we seem now to inhabit a world where important decisions and laws are made by people who lack the cognitive bandwidth to make any decisions of consequence. It seems to be getting worse with every passing year.
Post #1008857 25th Sep 2023 8:18pm
Retroanaconda
But it’s not impossible. If I turn the headlights off and just have the sidelights on they stay that way for quite a while, more than enough time to reverse to a passing place for example. I live 10 miles down a single track road and do it regularly in the winter.
I do completely agree that it would be much better to just have full control over what the lights do, but there’s a lot of misplaced drama here given they will actually do what people are wanting.
Post #1008864 25th Sep 2023 9:11pm
For clarity I have no experience with the new Defender, I was basing my comment on what was in the thread plus my own experiences with other modern cars (VW/Audi/Skoda) which won't let you drive on sidelights if it is dark.
Post #1008877 25th Sep 2023 9:51pm
Moo
Ukraine
In so many ways. Rolling Eyes Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1008879 25th Sep 2023 9:56pm
Retroanaconda
Dicky1961 wrote:
Yes that’s right, there is a sidelights position on the stalk, if you select sidelights and then pull away in the car, when you reach about 10pm they will go out and revert to front drl’s only. If you select sidelights whilst already driving they will stop on for a while until the car decides to revert back to drl’s only or until you stop and then pull away again then the car reverts to drl’s only. So by default there is not an option for sidelights.
This is not correct. I tested it this morning, pulled off the drive and turned the switch to the sidelights position, at which point the sidelights came on and remained on for the whole of my 40 mile drive to work.
In a situation where it’s dark enough for the headlights to be needed it will turn them back on after a while (as I described above) but in daylight conditions it will quite happily sit with side lights only for as long as you want.
Post #1009098 27th Sep 2023 9:57am
Dicky1961
Hi Retroanaconda, I can assure you that how I have described my cars behaviour is exactly how it behaves.
I have been back to the dealership with this and the technicians have been out in it and they don’t have any answers. JLR say it can’t be changed. I just drive with them set to auto now. Don’t like it just lump it. Big Cry
Post #1009104 27th Sep 2023 10:25am
Chris_DK
Denmark
Did anyone do this mod?
Did anyone do this mod? - and a step-by-step ? Smile
Best regards Chris
Post #1064296 31st Mar 2025 12:36pm
Page 2 of 2 <12
