Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 |
I use visual studio code with a diff plugin, excel tables sometimes, and even a sql db so I can use query language to do analysis. I'm one of the guys trying to figure out ACC, so I've used many tools to pull my hair out. Thinking of using an AI tool if I can find one that can handle that sort of thing.
Cheers, Kyle 20MY Defender 110 Fuji White |
29th Aug 2023 9:01pm |
holtenc Member Since: 15 Aug 2023 Location: TX Posts: 28 |
VS code. The built-in compare function worked really well for my needs.
29th Aug 2023 9:05pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1415 |
On a Mac I use a programme called Kaleidoscope, you can lay 2 or however many ccf files together and it highlights the differences shown by the blue lines. (I have blurred some personal details on the image)
Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
29th Aug 2023 10:39pm |
matt4x4 Member Since: 18 Nov 2022 Location: North Posts: 16 |
Notepad++ with the Compare Plugin
30th Aug 2023 8:09am |
NoWayMe Member Since: 15 Jan 2023 Location: Canada Posts: 6 |
thanks for the head’s up! Ran the updater and sure enough so far 2 of my 5 changes worked on first startup. Will let the others sit overnight and check again. |
31st Aug 2023 4:08am |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 |
Glad to see you are all getting it sorted and working.
1st Sep 2023 2:23am |
Okay so I got 007 screen, seatbelt remainder mute, auto start/stop remember and blinker/headlight combo to all work, but having trouble with dynamic mode. Am I doing something wrong? Or missing something? It’s been 1.5 days, numerous engine starts, 4-5 pivi resets …
I get the dynamic mode option screen but I can not see or select the dynamic mode icon with the rotary: Click image to enlarge Even though the icon shows up on my dash screen when I move the rotary (just can not move it beyond the ECO mode icon): Click image to enlarge I double checked that all files were correct as listed below: Click image to enlarge Any insight? Did anyone else see the same results? Do I just need to wait longer for it to take effect? Thanks for any info |
1st Sep 2023 5:34am |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 226 |
Might also need
MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout” My 562 is set to without timeout but not sure what different with or without makes |
1st Sep 2023 5:40am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 163 |
hello,
try not to change the multican 777, leave the default setting. initially it was not changed 777, the dynamic mode icon appeared on the touch screen and clicked on the screen. double check that all this is modified. if it doesn't work, post your total ccf sure we can compare it. Marco |
1st Sep 2023 6:30am |
MickD Member Since: 28 Jul 2023 Location: New England Posts: 28 |
This is what I had changed when it was working for me.
EUCD - 245 Dynamic 1 set to “Dynamic 1 Content with Configurable Dynamic Mode Screen” MultiCAN - 562 DynamicProgMode. Set to “Available for Selection Without Timeout” MultiCAN - 605 ConfigDynamicMode. Set to “Fitted” MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout” MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen” |
1st Sep 2023 12:40pm |
Try running this command on your IID tool Menu>Service Test>IDMA>Allow Central Configuration Data Learning and see if that allows selection. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
1st Sep 2023 2:56pm |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 107 |
I did not set MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout” , and mine seems to work fine WRT selecting past eco to dynamic. What do you get with DynamicLiteMode?
Also, I’m just in the habit of resetting the PIVI twice after each change that affects the HMI. |
2nd Sep 2023 7:51pm |
I set MultiCAN-740 Drive Away Door Lock to Disabled, and that worked, if anyone is interested in that.
I tried MultiCAN-514 StopStartInhibitIcon to Stop Start Inhibited Icon disabled (Non-CFSS), hoping to get the icon off the cluster while my auto stop start is inhibited, but that did something other than I wanted if it did anything. |
2nd Sep 2023 7:59pm |
aajr Member Since: 18 Dec 2022 Location: San Diego Posts: 32 |
I wonder if you set this to enabled it makes it go away? The way it is written, it seems to me that enabled means it is inhibited. |
3rd Sep 2023 1:13am |
