Home > Technical > TDCI door cards |
I believe you need the later white fir tree clips LRC1057 - EZM500050.
If the red base has broken (as happens a lot with the earlier yellow bases) you might have to use a small screw to attach the white clip to. |
28th Aug 2023 3:26pm |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 483 |
Thanks Geobloke, part ordered
28th Aug 2023 3:39pm |
Welcome. Good luck
28th Aug 2023 3:40pm |
