![]() | Home > Technical > TDCI door cards |
I believe you need the later white fir tree clips LRC1057 - EZM500050.
If the red base has broken (as happens a lot with the earlier yellow bases) you might have to use a small screw to attach the white clip to. |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 517 ![]() ![]() ![]() |
Thanks Geobloke, part ordered
Welcome. Good luck
