Home > Technical > Raised air intake
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Raised air intake
Hi!
Here in Brazil, we don't have lot of options for raised air intake, all are poor quality, the original is good one, but very very expensive for us here, what is your opinion for the original one?
(And, with this new electronic motor, how stay the water crosses?, isn't dangerous burn out the ECU crossing a river, or LR think about that and isolate it? or there is some tricks to isolate it from water?)
sorry about the bad english again!
Post #9931 20th Apr 2009 2:14am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Hi Gabriel, the RAI are expensive over this way too. I imported a Mantec from the UK and it worked out about 50% of the price that they wanted locally for one. Depending on how this works for Brazil but it may be a better option. Its easy enough to install and there is a really great picture gallery of an installation by AndrewS: Mantec) 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #9933 20th Apr 2009 6:48am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Gabriel - don't apologise for your English - it is very good.
I agree with dm_td5: the Mantec RAI is a good bet and shouldn't be too expensive to get shipped (they're not that heavy).
The ECU-driven Defenders are pretty good at wading. There is a known issue with the new PUMA engined Tdci, whereby the fuel tank breather needs to be repositioned (a DIY job - do a search on this forum) but other than that they are pretty robust.
The electrics are pretty well isolated unless you're planning on going VERY deep (in which case you'll be in danger of swamping the battery box under your seat). However, fording rivers should be OK. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #9936 20th Apr 2009 7:40am
Eduardo
Gabriel,
Welcome to here (don't worry about the english, some of us also have problems with it).
As Alantd and dm_Td5, I also imported a Mantec RAI at a reasonable cost (US$ 620 installed) and works pretty well.
Cheers Eduardo
Post #9955 20th Apr 2009 1:13pm
MK
You can try in Argentina. www.parque4x4.com.ar or http://www.tierraverde4x4.com/accesorios.htm Puma 110" SW
Post #9957 20th Apr 2009 2:59pm
Gabriel Boff
About the Mantec RAI's
Anyone know if the (1-DPSV-R/04) model or the (1-DSV5) fit for puma 2.4????
Because the (1-DPFL-R) model, (which is the only one that fit the puma 2.4 according tho the site!)
I think is a lot "futuristic"and don't match with the defender porpouse!
PS: I am a little "old fashioned"!!!!
Post #10029 21st Apr 2009 7:11pm
MK
I do not know the codes, but you can fit the typical one for Td5 or 300Tdi. Puma 110" SW
Post #10030 21st Apr 2009 7:22pm
Gabriel Boff
Thanks, for the answer, about the codes, you can see the respective models in the mantec's website.
Post #10031 21st Apr 2009 7:36pm
alantd
I believe the 1-DPSV-R/04 fits the Puma. In fact, if you have a roll cage, you need to get that model because the "plastic jobby" doesn't fit. One that started out as a 2.4 TDCi 110 XS
Post #10042 21st Apr 2009 10:43pm
