Home > Technical > Raised air intake |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 |
Hi!
Here in Brazil, we don't have lot of options for raised air intake, all are poor quality, the original is good one, but very very expensive for us here, what is your opinion for the original one? (And, with this new electronic motor, how stay the water crosses?, isn't dangerous burn out the ECU crossing a river, or LR think about that and isolate it? or there is some tricks to isolate it from water?) sorry about the bad english again! |
20th Apr 2009 2:14am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Hi Gabriel, the RAI are expensive over this way too. I imported a Mantec from the UK and it worked out about 50% of the price that they wanted locally for one. Depending on how this works for Brazil but it may be a better option. Its easy enough to install and there is a really great picture gallery of an installation by AndrewS: Mantec) 110 2.4TDCi
110 300Tdi LROCV ::: AULRO.com |
20th Apr 2009 6:48am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Gabriel - don't apologise for your English - it is very good.
I agree with dm_td5: the Mantec RAI is a good bet and shouldn't be too expensive to get shipped (they're not that heavy). The ECU-driven Defenders are pretty good at wading. There is a known issue with the new PUMA engined Tdci, whereby the fuel tank breather needs to be repositioned (a DIY job - do a search on this forum) but other than that they are pretty robust. The electrics are pretty well isolated unless you're planning on going VERY deep (in which case you'll be in danger of swamping the battery box under your seat). However, fording rivers should be OK. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
20th Apr 2009 7:40am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Gabriel,
Welcome to here (don't worry about the english, some of us also have problems with it). As Alantd and dm_Td5, I also imported a Mantec RAI at a reasonable cost (US$ 620 installed) and works pretty well. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
20th Apr 2009 1:13pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
You can try in Argentina. www.parque4x4.com.ar or http://www.tierraverde4x4.com/accesorios.htm Puma 110" SW
20th Apr 2009 2:59pm |
About the Mantec RAI's
Anyone know if the (1-DPSV-R/04) model or the (1-DSV5) fit for puma 2.4???? Because the (1-DPFL-R) model, (which is the only one that fit the puma 2.4 according tho the site!) I think is a lot "futuristic"and don't match with the defender porpouse! PS: I am a little "old fashioned"!!!! |
21st Apr 2009 7:11pm |
Thanks, for the answer, about the codes, you can see the respective models in the mantec's website.
21st Apr 2009 7:36pm |
I believe the 1-DPSV-R/04 fits the Puma. In fact, if you have a roll cage, you need to get that model because the "plastic jobby" doesn't fit. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
21st Apr 2009 10:43pm |
