Home > Technical > Whining Noise!
Page 1 of 3 123>
Zagato
Whining Noise!
I have recently heard a whine which sounds to come from the rear rather than the gearbox but maybe wrong. If you lift off the noise goes but comes back when under power again. It happens in 4th, 5th and 6th gear when at higher speeds probably 40 mph upwards.
It is booked in for the dealership to look at and I would like them to check the oil levels whilst investigating the problem. It's not very loud, the sort of standard noise you would get from a drive-train on an old mini for instance but I don't remember my TD5 having the noise. It may have done it from new but rarely drive with the radio off and on faster roads 50mph + so not sure it's a new thing or not.
Searching brings up all sorts which I will continue to wade through...any ideas?
It is very similar but a lot quieter to the howling rear axle I have on my 109 once it gets warmed up!!
Post #100293 16th Nov 2011 11:29am
spudfan
Ireland
Would'nt be something as simple the propshaft being fitted incorrectly i.e not lining up with the aligning marks?
Suppose you checked the coupling for adequate grease. Knowing you I feel sure you have eliminated both these causes. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #100381 16th Nov 2011 6:34pm
have a good look underneath in the light, I found a few stray items on mine, simply clipped into place.
also check around the brake discs and abs cables.
did you lift the suspension ? If so, probably propshaft related, check you nipples too
keep us informed Thumbs Up
Post #100393 16th Nov 2011 7:53pm
ZeDefender
Re: Whining Noise!
Are you sure it wasn't Amy?
My daughter is still Censored off we bought a Defender "instead" of using the money to put down a deposit on a flat for her Rolling Eyes Tell someone you love them today because life is short.
Post #100399 16th Nov 2011 8:14pm
T1G UP
rear diff i expect
Post #100438 16th Nov 2011 10:02pm
DAZ110
Must be the wife Whistle
Post #100440 16th Nov 2011 10:04pm
TACK
Re: Whining Noise!
You can live in a defender, you can't drive a house Mr. Green Rolling with laughter
Post #100459 16th Nov 2011 10:42pm
Zagato
T1G UP wrote:
rear diff i expect
Agreed, will do searches on rear diffs Thumbs Up It's booked in for the 28th! Does anyone else have a noise once it's warmed up after a few miles at speed?
and I couldn't think of a better way of spending your daughters inheritance ZeDefender Wink
Post #100483 17th Nov 2011 7:21am
ZeDefender
Zagato wrote:
T1G UP wrote:
rear diff i expect
Very Happy Tell someone you love them today because life is short.
Post #100486 17th Nov 2011 7:46am
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Re: Whining Noise!
That will be me tomorrow if you ask too many difficult questions..... Very Happy Whistle Thumbs Up Jon - 110 td5 [sold]. Currently Defenderless.
Post #100488 17th Nov 2011 8:05am
Zagato
OK Jon, heres the plan, you ask the heavy questions and whilst they are distracted I'll whack in a few diffs and gearboxes into Johns sankey Wink Have you got the hidden camera sorted for the factory tour yet Twisted Evil
Post #100523 17th Nov 2011 1:10pm
spudfan
Ireland
Vehicle seems very young to be giving diff. worries. 1982 88" 2.25 diesel
Post #100583 17th Nov 2011 7:06pm
Zagato
Yes 3300 miles now Spud, never towed anything significant in weight, never offroaded etc. The more I hear the noise the more I think it is the gearbox! I can get it to make the noise at 2000RPM at about 40 - 50 mph and can get it to be quite loud which is almost a relief so it can be identified easily hopefully sorted properly.
I will be towing 2 tonnes 200 miles the day before it goes in so that might help Censored it up a bit more Very Happy It sounds like a 1960's car gearbox whine, only when under load!
Post #101113 20th Nov 2011 8:17am
110SEB
Dont you all know?
"....They all do that, Sir."
Rolling Eyes Good luck tracing this one.
Post #101120 20th Nov 2011 9:07am
RED-DOT
Even ice-creamers make noise? Input shaft bearings sometimes need re torquing? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #101140 20th Nov 2011 10:31am
Page 1 of 3 123>
