![]() | Home > Technical > Whining Noise! |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Would'nt be something as simple the propshaft being fitted incorrectly i.e not lining up with the aligning marks?
Suppose you checked the coupling for adequate grease. Knowing you I feel sure you have eliminated both these causes. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
have a good look underneath in the light, I found a few stray items on mine, simply clipped into place.
also check around the brake discs and abs cables. did you lift the suspension ? If so, probably propshaft related, check you nipples too keep us informed ![]() |
Are you sure it wasn't Amy? My daughter is still ![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
rear diff i expect
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2050 ![]() ![]() |
Must be the wife
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
You can live in a defender, you can't drive a house ![]() ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Agreed, will do searches on rear diffs ![]() and I couldn't think of a better way of spending your daughters inheritance ZeDefender ![]() |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
That will be me tomorrow if you ask too many difficult questions..... ![]() ![]() ![]() |
OK Jon, heres the plan, you ask the heavy questions and whilst they are distracted I'll whack in a few diffs and gearboxes into Johns sankey
Vehicle seems very young to be giving diff. worries. 1982 88" 2.25 diesel
Yes 3300 miles now Spud, never towed anything significant in weight, never offroaded etc. The more I hear the noise the more I think it is the gearbox! I can get it to make the noise at 2000RPM at about 40 - 50 mph and can get it to be quite loud which is almost a relief so it can be identified easily hopefully sorted properly.
I will be towing 2 tonnes 200 miles the day before it goes in so that might help ![]() ![]() |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Dont you all know?
"....They all do that, Sir." ![]() |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Even ice-creamers make noise? Input shaft bearings sometimes need re torquing? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
