![]() | Home > In Car Electronics (L663) > Editing Favourites in Pivi Pro |
DaveCNB Member Since: 15 Mar 2022 Location: So. Cal Posts: 63 ![]() ![]() |
So after you save a destination to your Favorites,
Go into your list of Favorites (yellow star in a circle icon) in the Privi Nav search screen ![]() Click image to enlarge Press the Pencil icon at top left (circled in red): ![]() Click image to enlarge Select the saved Favorite that you want to edit. To edit the name, again press on the pencil icon (circled in red): ![]() Click image to enlarge That will bring up a full screen keyboard so you can change the name. Click the blue OK button bottom right when you're done, make sure to select the Check/OK icon at the top right to save your changes: ![]() Click image to enlarge That should do it. Cheers, Dave -------------------------------- "Chonky" 2024 Defender 110 X-Dynamic SE P400, Pangea Green, Air Suspension, Off Road Pack, Urban Pack (exposed recovery points), Factory Side Steps |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 103 ![]() ![]() |
Many thanks. Problem solved.
