Home > Maintenance & Modifications > Defender Rear Sliding Window Locks. |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Funnily enough - one of mine came off in my hand this week due to bi-metal corrosion from over 12 years by the sea side
I ordered on in from John Craddock and it was the same as the original one - took 10 mis to swap over and now toying with the idea of changing the other one later in the year ... Never had a problem with these from a security point of view but have internal window grills fitted for the camper set up anyway ... so one of those ‘layers' to slow down possible issues Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
19th Jul 2023 4:56pm |
humby Member Since: 19 Aug 2022 Location: South Posts: 27 |
To be honest i hadn't thought about security for those latches and i did recently change the exterior aluminium blocks as mine had weathered badly.
It was only today as i stopped to chat to a neighbour that has a load of defenders out front that mentioned those rear latch windows you can open a particular way that got me thinking about it. Ill spend some time googling, i dont have any grills on my windows if i can avoid them too id like to be grill-less |
19th Jul 2023 6:46pm |
So seems like the only product for the slide windows is guards. There is no aftermarket lock mechanism etc that can be installed to add a layer of security to the sliding windows.
24th Jul 2023 7:18pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5872 |
Or a bit of wood between the lock and the other glass section of the window? 1999 Defender TD5 110
24th Jul 2023 8:14pm |
You gave me an idea! I am working on something.
25th Jul 2023 4:31pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
I have blue box sliding rear side windows on my 110 CSW and they have a completely different catch where one part hooks over the other on the vertical part of the frame.
Not to everyone's taste I know as they don't quite look original but they do look a bit more secure (didn't stop some scrote from breaking the glass and nicking my recovery gear bag mind you). 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
25th Jul 2023 8:12pm |
