Home > Puma (Tdci) > Tdci bonnet pin ripped from bonnet |
Sam smith Member Since: 12 Aug 2021 Location: Suffolk Posts: 65 |
I recently bought a project defender tdci and the pin has been ripped out of the bonnet which looks like it could be a tricky one to repair but I have to try. Is the pin located directly in the centre of this middle section any recommendations on best course of action?
Photo attached Many thanks |
18th Jul 2023 7:13am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 486 |
Your only easy option is a flat plate with nut welded on the back to except the bonnet striker and then two rivnut fixings to underside of bonnet. However you do it make sure the pin can withstand the windforce applied to the bonnet at motorway speeds
18th Jul 2023 9:51am |
yeah that is a bit of a concern but hopefully i can make it as strong as oem i think my bigger concern is the alignment of the pin and height of it. i assume the pin threaded bit goes dead centre of the central support or is it off centre? i also assume that the metal braket bit it sits on should be level with all the others along the edge of the bonnet?
many thanks |
18th Jul 2023 8:54pm |
i take it it is meant to go dead centre of that supportive bracket? and the height should be the same as the others? cheers |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
It’s flush with the rest yes and central.
18th Jul 2023 9:13pm |
ok great thank you!
21st Jul 2023 6:10am |
