![]() | Home > Td5 > Td5 misfire |
Ok so white smoke at startup in my TD5 was the head gasket. It was an incredibly subtle when the gasket was inspected but there was a minor track between the cylinder and oil gallery.
What does the white smoke smell like? Oily? My TD5 smelt pretty bad, but cleared up as the engine got to temperature. It only happened on a cold start after sitting for a hours. Ok. sorry for the potentially bad news. ![]() |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 ![]() ![]() ![]() |
I think I had white smoke some time ago. I took out the EGR valve and replaced it with a regular ol' straight piece. You can find kits online. Might do the trick for ya. 2003 90 TD5 Hardtop
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
Could also be an injector on the way out 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5258 ![]() ![]() |
Fuel pump could be starting to fail too, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
dhep72 Member Since: 24 Apr 2023 Location: scotland Posts: 7 ![]() ![]() ![]() |
Have now tested the pump pressure and it's good , replaced the crank sensor and no improvement but now getting a crank sensor fault
the crank sensor loom can go faulty mind, and cheap sensors are rubbish Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
It's a Hella was hoping that it was a quality make.
you got to buy the genuine stuff sadly. They cost a bomb sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
You can roll the dice on a second hand LR sensor. I did. All good.
Had no fault logged with the old sensor installed
its not the crank senor then, it might be worth checking the fuel pump relay to see how that is connection wise. I replaced mine for the sake for a £10, when i was having the same trouble.
![]() Also banging in some decent Diesel injector treatment wont hurt either, Doing the cheap hits 1st, ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Have now swapped the relays with good ones from a other defender, and added some diesel treatment, when the codes are read it's a can fault that comes up
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Ignore the CAN fault. There’s no CAN network in it. What tool are you using? Can you look at cylinder balance? How did you set the injectors up? Does it only misfire at start after sitting? Any diesel in the oil? Loosing any coolant? What fuel map is on it?
using a Launch CRP919X, cylinder balance is fine, set the injectors up screwed all the way down and back one turn, only misfires on a cold start up or if its been sitting for about a couple of hours only from about just above tick over to about 2000rpm whitish grey like unburned fuel occasionally it will start with no problems at all, some times it takes a few turn to start but mostly it starts straight up. no diesel in the oil, not losing any coolant and its a standard map.
