![]() | Home > Td5 > Defender Td5 gearbox R380 Driving style |
charisme1 Member Since: 23 Oct 2019 Location: Paris Posts: 39 ![]() ![]() |
Bonjour Mike C, Thank's for your speedy reply. Did you have a chance to drive an R380 from new ? Does it need a momentary pause on neutral before upshifting to 2d and 3d even from new ? Without high reving on the changes and being gentle on the gas ? Cheers ! |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
I have never driven a vehicle with an R380 from new. I’ve never experienced any issues with mine over approx. 40,000 miles of ownership. Mine is standard mated to a TD5. I use LR MTF94 and change it more frequently than the service schedule suggests. I don’t drive quickly or aggressively. I think they are fine - notwithstanding that yours may have currently undiagnosed faults/issues.
Hi Screbble. Did you try to drive it like a normal car, hireving and up-shifting quickly ? I have this issue/fault (if it is one) only upshifting from 1st to 2d, and 2d to 3d, only when I rush the gears with high rpm. Never when downshifting. Many thanks for your input
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 368 ![]() ![]() ![]() |
I have a reconditioned R380 gearbox and can drive it almost like a normal car. When it gets really hot the gear change gets a bit clunky but it does not need me to pause briefly when shifting. TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 932 ![]() ![]() ![]() |
Hello charisme1, no I am unable to comment about an owned from new r380. 2004 Defender 90 Td5 CSW 2002 Discovery 2 td5 GS (gone) 1994 Defender 90 300Tdi CSW (gone) |
I don’t tend to rev too highly, but I’m not consciously not driving like a ‘normal car.’ I haven’t really thought about it properly, but I might pause slightly when passing through neutral. I can’t say I’ve noticed anything unusual when upshifting. I’ll need to go out later and pay attention! Having said all that, I still don’t think it feels fundamentally different to the other cars in our household (which aren’t Defenders!) but maybe I’ve just got a good gearbox… I hope you solve your problem ![]() |
murph81 Member Since: 11 Sep 2022 Location: Ireland Posts: 63 ![]() ![]() ![]() |
I have noticed this issue with my 110 lately, the gearbox has only done 56k miles from new.
Hi murph ! Did you change the oil ? As your gearbox seems new with only a few miles on it. Or maybe this a characteristic behavior of R380. Means not to high rev while up shifting quickly on lower gears. Maybe box needs to be gentle with it, with a pause on neutral for a second and no agressive rpm. Anybody here drove a R380 from new that can comment ? Thx
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
I recently had a bit of a snatchy/rough box at high rpms, much more noticeable after my remap. I changed the fluid (Granville mtf94) to genuine Land Rover mtf94 and have had a huge improvement. It’s not so buttery when it’s at high temps so I’ve recently fitting a gearbox cooler and I’m hoping that’ll keep the shifts smooth and potentially stop the oil from being cooked.
Fitting an R380 cooler has certainly helped protect the oil in Miffy
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
I wouldn’t give granville oil to my worst enemy, it’s not regarded as a good product
Whereas I WOULD give it to my worst enemy
Haven't changed the oil in my ownership, have only put 2k miles on it so far but I will be doing it soon once I sort some good quality oils. I have tried shifting a bit more gingerly today, hard to know yet. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5239 ![]() ![]() |
yeah these boxes don't like been rushed, i always sort of pause as you say to get the best changes. learned this with the 300 TDi. ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
