Home > Series Land Rovers > Interesting series.
Page 2 of 3 <123>
Dinnu
Would the length of the shadow give away about the wheelbase?
Brake light and indicators are up side down? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999737 12th Jul 2023 7:54am
I did look at that, and again find it hard to be sure. I think that the shadow in the rear view shows more rear overhang behind the rear wheel that you would see on an an 88", it looks to me more like a 109" shadow, but I wouldn't say it was conclusive.
No, the vehicle is correct, the SII, SIIA and SIII models have the indicators above the tail/brake lights.
My old SII (which sadly I sold due to a lack of storage space some time before prices rocketed) left the factory without indicators, but would have had the tail lights in the lower of the two positions in the rear corner cappings. The SII corner cappings were always designed to allow for a second light unit, and the early ones had the hole in the galvanised capping but the panel behind was solid. A SII without indicators looks odd (and is now a very rare thing). This can just be made out in some of the illustrations in the picture below (a screenshot of a page of an original brochure currently for sale at a very silly price on Ebay).
Post #999755 12th Jul 2023 9:20am
Dinnu
Good information Blackwolf Thumbs Up
Have limited knowledge about IIs and IIAs, usually I identify from the wiper motors.
Interesting in the screen capture of the brochoure that there is only a side light on the mudguard. I have seen II2 or IIAs with an indicator beside the side lamp, and others with the indicator above the side lamp.
Edit I am aware that SIIs VIN number starts with a 1 and IIAs with a 2, with 4th digit being the build year. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999760 12th Jul 2023 9:43am
Yes, at the front on early SIIs (like mine) there was no pressing for the indicator light, and if fitted it was simply attached in a suitable place. The fitting instructions for the optional flasher kit, which did include amber light units for front and rear, instructed that the hole should be cut inboard of the existing sidelight but that the sidelight should be moved to the new hole and the indicator fitted in place if the sidelight, so that the indicator was outboard of the sidelight. This was, I believe, in order to comply with the then-current lighting regs. More commonly the indicator was fitted below the sidelight since this was equally legal but could cause number plate problems.
Post #999780 12th Jul 2023 12:45pm
22900013A
blackwolf wrote:
My memory tells me that the lights moved to the wings in 1968 but still with a wire mesh grill. The plastic grill arrived with the S3.
If so the wings are correct and the radiator panel isn't, which is a little unusual.
Lamps moved on all markets in Spring 1968, probably march. Some export markets had moved by late 1968. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #999803 12th Jul 2023 4:52pm
22900013A
Series IIs and IIAs until 1967 had twin wiper motors. Single motor came in April 1967 with the black dash panel and negative eirth electrical system.
Series IIAs had no year identifier on the chassis number, instead they had the suffix letter to indicate the variant (progressing starting with letter A). 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #999804 12th Jul 2023 4:55pm
Dinnu
Pictures of the side light / indicators. The latter is most interesting LR, but also like because its an 88”.
Post #999806 12th Jul 2023 5:06pm
22900013A
The bottom one is military. They had up down lamps to leave space for the tall number plate layout in three rows of two digits. Civvy were side by side to give enough room for the standard civvy plate. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #999975 13th Jul 2023 7:05pm
L110CDL
Great read on this series Very Happy
Yes it's a 109" Thumbs Up
When i'm passing the series next i will get some more pics for you Smile Clayton.
Keeper.
Post #999995 13th Jul 2023 7:59pm
Dinnu
22900013A wrote:
The bottom one is military. .
Yes. Also the headlams are different, they look same as the lightweight headlamps. I wish to bring that one home, but lack of space makes it an issue Big Cry 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1000000 13th Jul 2023 8:17pm
Screbble
I have often wondered about that - and what you say makes perfect sense 👍
Post #1000007 13th Jul 2023 8:44pm
Bottom one's earlier than the one above, too, since it has the original folded modesty valance. Top one has the later pressed type.
Post #1000011 13th Jul 2023 9:36pm
Linds Hanson
camelman wrote:
My understanding was the 2.6 was only available in the 109? Could be wrong though...
Correct
Post #1000090 14th Jul 2023 11:18am
L110CDL
As i was passing the 109 this morning i was able to stop and get a few more pics, sadly no one was about to ask about it Sad
Inside the 109
Thumbs Up Clayton.
Keeper.
Post #1000595 17th Jul 2023 7:40pm
Definitely a 2.6 bulkhead.
Definitely needs love!
Post #1000606 17th Jul 2023 8:03pm
Page 2 of 3 <123>
