![]() | Home > Technical > 2.4 Coolant engine warming pre and post 11MY. |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
I remapped a large fleet of new 110's earlier on this year, and a load of them had faulty thermostats. These were stuck closed though, and so would cause overheating.
It at least gave me a rare chance to see the overheat protection strategy kick in from the ecu! ![]() They have the exact same thermostat as fitted to Td5, and according to our friendly local land rover parts department, these generally never go wrong. I suspect there may have been a sub standard batch get through the system though, and no doubt there may be a bulletin released shortly for the benefit of freezing defender owners. ![]() |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
I don't think mine takes much longer (if at all) to warm up than my 07 Puma did - IIRC it was about 10 - 15 mins today. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5025 ![]() ![]() |
Agreed 10-15 mins and it's ferocious once warmed up. The temp adjustment takes a while after turning the knob though!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
Out of interest, does the heater work any better on the '11 MY Defender, ie is the temperature now stable, is it controllable, and is the air from the LH side outlet the same temperature as the RH side?
Or does it still fluctuate between ice and fire with nothing in-between, and scorch the passenger at the same time as freezing the driver, like the original Puma heater? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
so with the heater running on full chat and the fan on pos 1 in start/stop traffic and upto 30mph does the engine temp go down with ambient around +3 to +5? Cheers
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I had a TD5 that would never heat up past the blue and after my second winter of freezing my nuts off i complained about the cold engine. I was told that Defenders have two grades of thermostat, one for hotter climates and a colder (europe) unit. It was pointed out that a Defender has to cool a vehicle towing a 3.5 ton trailer through a desert and then cross ice and snow covered mountains.. no thermostat can cope with that range. Instant fix. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Getting the temp right is a constant fiddle helped only by the air con. With air-con off and the heating turned full on nothing or hardly anything comes through unless you turn the fan on ![]() ![]() |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
Maybe worth mentioning as I spent a couple of days thinking my heater was broken but turning the air-con on automatically gives you fan position 1 (if it's set at 0) |
Yes it seems the fan has to be on to get any effective heat through....the constant fan noise although not loud is annoying on a long journey...
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
My puma 110 must be a good one it is fully warmed up within a mile.
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Within 3 miles and warm air is coming out of the vents (a/c on) .
8 miles and the temp gauge is sitting just a smidge below halfway and stays there regardless of outside/inside temps. Temperature control knob location (regardless of the red/blue graduation) is either hot, 'kin hot , very warm , cool or cold. On every journey over 30 mins in duration I'm opening the window to help regulate the temperature. Temp seems to be the same on driver or passenger side. I was led to believe these are all features ![]() Stu |
Yes the temperature control is not exactly linear.
Timed mine this morning and warm air was coming out properly after 4 mins - pretty good and agree with you Stu, I either have to keep turning the air-con on and off or opening the window to adjust the temp ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4773 ![]() ![]() |
Heater on my 2011 Puma is more adjustable heatwise than the earlier 2008 Puma.It is possible to have a moderate heat than either an inferno or nothing.Also as with the 2008 it warms up very quickly.Great in this weather. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
