![]() | Home > Technical > 2.4 Coolant engine warming pre and post 11MY. |
mines fine, sits just under half way quick enough.
Mine's LHD and there is a known problem with the driver side being hotter than the passengers, apparently the fix is to tape/block off part of the heater matrix for the driver side. that aside, mine heats up within a few miles.
has anyone used a radiator muf this year ? if so, was it genuine, aftermarket or home made? Picture please ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
so are there two thermostats available for the td5/Puma - assuming its the same one? Cheers
