Home > Wheels & Tyres > What Size Tyres
Page 2 of 2 <12
110SEB
Thumbs Up
Post #7651 23rd Feb 2009 11:26am
DAZ110
Chalky,
You can fit without wheel spacers, but they do improve the steering lock once steering stops are adjusted.
Daz110
Post #7656 23rd Feb 2009 2:49pm
Genis
South Africa 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
255/85 R 16's fit without any rubbing so far. That's on a 90. Tested it on a few cross-axles without any load in the back and it cleared, but it's tight.
Post #7712 24th Feb 2009 11:31am
Andrew388
South Africa
As I understand it, the biggest size one can go without modification is 265 75 16.
Genis: where did you get that size tyre? I have been looking, but no one sells them in SA that I know of.
AndrewS: is your suspension standard on the 285's?
I have a 90 with 2 inch lift and disconnected anti-sway bars, and am hesitant to fit 285's for fear of them rubbing on articulation. My truck has an RTI of 761 already, and I still need to fit the longer shocks, so there is a high possibility that the tyres will rub on full articulation with 285's.
Post #7740 25th Feb 2009 10:38am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Pob wrote:
85 is the percentage of height of the wheel/tyre diametre and the 16 means 16" wheel ?
85 is 85% of the tread width.
So the wall on say a 285 wide tyre is 85% of the width which is 242.25mm high Thumbs Up
Post #7796 26th Feb 2009 8:25pm
Page 2 of 2 <12
