![]() | Home > Puma (Tdci) > Puma 2009 2.4 injector codes 8 or 10 digits? |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 562 ![]() ![]() ![]() |
I reckon it should be a set of 4 (1 per injector) 16 digit hex code (as seen in your screenshot of the tool) - On mine, there was a sticker from factory with the codes (the sticker is now long gone though, but I kept a picture…):
![]() Click image to enlarge HTH “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 196 ![]() ![]() ![]() |
As above. On the 2.4, each injector has a code, and it's a 16 digit hex code.
You can find the code for each injector on the top of the plastic electrical connector of the injector, written on 2 lines. Example in pic below. /Mat ![]() Click image to enlarge |
Why do we do it Member Since: 16 Mar 2025 Location: Oxfordshire Posts: 8 ![]() ![]() ![]() |
Many thanks for your replies. The handwritten codes in the picture are what is written on my injectors. as I have a 10 digit option on The diagnostic tool.any ideas on what I should install as an injector code from my list of handwritten codes?
I just remembered there is a barcode on the injectors as well. Maybe this will give him more codes to choose from the only problem is I need to take the injectors out again again to read the barcode as they are on the inaccessible side.. … |
Your handwritten codes are not valid injector codes for the puma 2.4
As already stated, the only valid injector code format is a 16 digit hex code for the 2.4 Please check this link : https://bellautoservices.co.uk/bas2rrc-hel...ogramming/ /Mat Last edited by MatLandy on 4th Apr 2025 8:22am. Edited 1 time in total |
Many thanks for the link Matt.
I’ll take a look this weekend.fingers crossed… |
Ok….so found the correct injector codes right, where you said they would be.
So compared the injector codes to what my diagnostics tool was saying and the codes are identical the only error message I get now is to do a injector learning program when I try to do this I get to the very last stage and the diagnostic tool states a error in communications Tried wiping all of the error codes again and starting the sequence but still get the same message just wondering whether my Icar3 diagnostics tool doesn’t support this operation but it seems a bit weird that as you would think this was a standard function for most diagnostictools? Also, if I try to edit an injector code, I get to the very last stage and again get the loss of communication error. Does anybody have an idea on what I might be doing wrong or what the problem might be? Looking forward to your comments. |
