Home > Puma (Tdci) > Puma 2009 2.4 injector codes 8 or 10 digits?
Why do we do it
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Aintree Green
Hi can anyone shed some light on light on a injector coding issue.
I have recently bought a diagnostic tool to enable me to code my injectors to my truck
The tool takes me through a fairly logical process to get to the point where I have to input a 10 digit code. The problem I have is on my injectors have multiple codes written on the top and etched around the side. None of these codes have an obvious 10 digit layout. They only have eight digits also with lettering that is not available in my diet machine options..
The injectors (Denso) are the original units that came with the truck, although probably not the original units from birth. I’m sure it’s something obvious. It’s just the first time I’ve tackled this job and need a bit of guidance. Looking forward to the advice. Please see pic of the codes. I have got off the injectors. And a picture of the l The codes that my Diagnostic tool reads from the ECU.
Many thanks in advance..
Post #1064483 2nd Apr 2025 7:35am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I reckon it should be a set of 4 (1 per injector) 16 digit hex code (as seen in your screenshot of the tool) - On mine, there was a sticker from factory with the codes (the sticker is now long gone though, but I kept a picture…):
HTH “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1064485 2nd Apr 2025 7:54am
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
As above. On the 2.4, each injector has a code, and it's a 16 digit hex code.
You can find the code for each injector on the top of the plastic electrical connector of the injector, written on 2 lines.
Example in pic below.
/Mat
Post #1064521 2nd Apr 2025 5:07pm
Why do we do it
Many thanks for your replies. The handwritten codes in the picture are what is written on my injectors. as I have a 10 digit option on The diagnostic tool.any ideas on what I should install as an injector code from my list of handwritten codes?
I just remembered there is a barcode on the injectors as well. Maybe this will give him more codes to choose from the only problem is I need to take the injectors out again again to read the barcode as they are on the inaccessible side.. …
Post #1064627 3rd Apr 2025 7:48pm
MatLandy
Your handwritten codes are not valid injector codes for the puma 2.4
As already stated, the only valid injector code format is a 16 digit hex code for the 2.4
Please check this link :
https://bellautoservices.co.uk/bas2rrc-hel...ogramming/
/Mat
Post #1064632 3rd Apr 2025 8:20pm
Why do we do it
Many thanks for the link Matt.
I’ll take a look this weekend.fingers crossed…
Post #1064643 4th Apr 2025 7:41am
Why do we do it
Ok….so found the correct injector codes right, where you said they would be.
So compared the injector codes to what my diagnostics tool was saying and the codes are identical the only error message I get now is to do a injector learning program when I try to do this I get to the very last stage and the diagnostic tool states a error in communications Tried wiping all of the error codes again and starting the sequence but still get the same message just wondering whether my Icar3 diagnostics tool doesn’t support this operation but it seems a bit weird that as you would think this was a standard function for most diagnostictools?
Also, if I try to edit an injector code, I get to the very last stage and again get the loss of communication error.
Does anybody have an idea on what I might be doing wrong or what the problem might be? Looking forward to your comments.
Post #1064682 4th Apr 2025 7:13pm
o4dn
Not sure whether it's the same problem with your diagnostic tool, just sharing what happened to me the last time I tried.
AFAIU, the injector learning sequence is actually performed by the ECU itself, the diagnostic tool just initiates it (if the requirements like engine temperature of 80°C is met)
Once started, the ECU will do all sort of adjustments for several minutes, you'll hear the engine tone changing while it runs.
So, long story short, the last time I ran the procedure a couple of weeks ago using my Nanocom, I had a communication error as well as soon as the procedure started, but then I left it running all by itself until completion. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #1064735 5th Apr 2025 10:13am
MK
Nowadays, with modern test benches you can get new codes adjusted to the degree of wear of the injectors. However, I am not sure if it is worth to do it on older EuroIV systems. Puma 110" SW
Post #1064762 5th Apr 2025 5:19pm
Why do we do it
So my diagnostic tool doesn’t seem to even trigger the self test still keeps coming up with a comms error.
Not sure of next move.
Maybe a higher grade tool might be more successful.
Post #1064788 5th Apr 2025 8:37pm
Ianh
A Nanocom at the latest software build or an IDTool will do it . BUT for any tool the engine needs to be above 75c and below 80c according to Bell Auto service (BAS) a highly respected tuner of defenders.
Post #1064799 5th Apr 2025 11:11pm
Why do we do it
Thanks IanH,
I’ll try at a higher temperature. And track down a Nanacom unit.
Update soon..
Post #1064808 6th Apr 2025 7:03am
o4dn
Ianh wrote:
[...] BUT for any tool the engine needs to be above 75c and below 80c according to Bell Auto service (BAS) a highly respected tuner of defenders.
Yet the Nanocom SW won't start the procedure if the coolant temperature is less than 80°C “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #1064818 6th Apr 2025 9:01am
