![]() | Home > In Car Electronics (L663) > Pivi Pro playing up, no sound. |
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 75 ![]() ![]() |
Can you not reset privi by holding down Center of volume button for about 20 seconds 🤔 My 24 HSE X-Dynamic 90 Carpathian Grey
billy2shots Member Since: 23 Oct 2024 Location: England Posts: 41 ![]() ![]() |
Holding that down does nothing.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
Are you doing it while stationary and in park, but with the engine running?
And also holding it down long enough? My 24 HSE X-Dynamic 90 Carpathian Grey
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Happened to me a few times over the years... normally sorts itself out after the car goes to sleep (leave it locked for 30+mins I think)
but disconnecting the battery for a moment also does the trick (tip: enable service mode on the remote app so they don't think it's been stolen) Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 310 ![]() ![]() |
Before disconnecting the battery, with the subsequent danger to the car, I would remove and after place again the blue fuse 51 from the trunk fuse box....and if it doesn't work any other related one from the list that appears in the user manual!
good luck! ![]() ![]() ExDiscovery 3 TDV6 SE |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 111 ![]() ![]() |
Ha ha i know what you mean. I disconnected the battery to fit new steering wheel and within 30 seconds Land Rover were on the phone! at least it shows its working! |
