Home > In Car Electronics (L663) > Pivi Pro playing up, no sound.
billy2shots
Two times in the last 5 days I've had the following -
Unable to play any music
No connection to Alexa
Sat nav works but it's muted
Can start a phone call but auto uses my handset, no speaker or mic via car.
Volume button does nothing on screen or on wheel.
Can't reset screen as powered button does nothing. Turning car off for a few minutes sorted it last time.
Can't be the only one?
D350
Post #1063750 24th Mar 2025 3:18pm
Down & Dirty
Can you not reset privi by holding down Center of volume button for about 20 seconds 🤔 My 24 HSE X-Dynamic 90 Carpathian Grey
Post #1063751 24th Mar 2025 3:34pm
billy2shots
Holding that down does nothing.
Post #1063780 24th Mar 2025 8:08pm
Retroanaconda
Are you doing it while stationary and in park, but with the engine running?
Post #1063783 24th Mar 2025 8:38pm
Down & Dirty
And also holding it down long enough? My 24 HSE X-Dynamic 90 Carpathian Grey
Post #1063784 24th Mar 2025 8:55pm
Cheshire110
Happened to me a few times over the years... normally sorts itself out after the car goes to sleep (leave it locked for 30+mins I think)
but disconnecting the battery for a moment also does the trick
(tip: enable service mode on the remote app so they don't think it's been stolen) Cheers, David
Post #1063789 24th Mar 2025 9:34pm
ruben
Spain
Before disconnecting the battery, with the subsequent danger to the car, I would remove and after place again the blue fuse 51 from the trunk fuse box....and if it doesn't work any other related one from the list that appears in the user manual!
good luck! Thumbs Up Thumbs Up Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1063806 24th Mar 2025 11:10pm
Colin68
Ha ha i know what you mean. I disconnected the battery to fit new steering wheel and within 30 seconds Land Rover were on the phone! at least it shows its working!
Post #1063812 25th Mar 2025 8:52am
