Home > Technical > Spare wire behind radio console
Shifty123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Barolo Black
I have found a random wire behind centre console when removing parrot hands free, any ideas on its purpose before I need to remove half the interior finding the other end?
It’s green/white and in its own sleeve .
Post #1063440 20th Mar 2025 7:06pm
macfrank
remote antenna?
Post #1063442 20th Mar 2025 8:01pm
Ianh
Which defender do you have , I.e TD5, Puma etc.
On a TD5 I think the antenna wire is Orange / Slate and on a Puma I think it’s white.
Knowing which vehicle you have helps us point you to the correct wiring diagrams.
Post #1063445 20th Mar 2025 8:51pm
Shifty123
2.4 puma , hope someone can shine a light or it’s a weekend strip down
Post #1063462 20th Mar 2025 10:55pm
I suspect that it is the aerial for the 10AS unit.
Post #1063471 21st Mar 2025 12:05am
Ianh
Sorry, by antenna I meant the 10AS aerial.
According to the wiring diagrams on the TD5 and 2007 -2011 Puma it’s orange slate. On 2012 -214 Puma its white.
Have a look on LRworkshop for wiring diagrams , https://www.lrworkshop.com/diagrams click on menu , then electrics and then pick your vehicle.
The Lucas wiring code will help you narrow down to which wiring diagramo look at . https://www.jcna.com/lucas-wiring-colors-0
Post #1063474 21st Mar 2025 12:45am
Shifty123
Thanks for the diagrams, they will be handy.
Unfortunately I can’t see my wire but I have traced it back to a relay in the battery compartment . As far as I’m aware LR didn’t put relays in there so much be something aftermarket. More investigations required I think
Post #1063557 21st Mar 2025 7:11pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Have you got towing equipment fitted, with a 13 pin socket. I’m sure the green/white is used to trigger the relay, to give a 12v switch live to the tow socket. I may be totally wrong, but worth a look,
Ashby Andy 👍🤔
Post #1063560 21st Mar 2025 7:42pm
