![]() | Home > Technical > Spare wire behind radio console |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1110 ![]() ![]() ![]() |
remote antenna?
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2220 ![]() ![]() |
Which defender do you have , I.e TD5, Puma etc.
On a TD5 I think the antenna wire is Orange / Slate and on a Puma I think it’s white. Knowing which vehicle you have helps us point you to the correct wiring diagrams. |
Shifty123 Member Since: 20 Mar 2025 Location: Bedfordshire Posts: 3 ![]() ![]() ![]() |
2.4 puma , hope someone can shine a light or it’s a weekend strip down
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17675 ![]() ![]() ![]() |
I suspect that it is the aerial for the 10AS unit.
Sorry, by antenna I meant the 10AS aerial. According to the wiring diagrams on the TD5 and 2007 -2011 Puma it’s orange slate. On 2012 -214 Puma its white. Have a look on LRworkshop for wiring diagrams , https://www.lrworkshop.com/diagrams click on menu , then electrics and then pick your vehicle. The Lucas wiring code will help you narrow down to which wiring diagramo look at . https://www.jcna.com/lucas-wiring-colors-0 |
Thanks for the diagrams, they will be handy.
Unfortunately I can’t see my wire but I have traced it back to a relay in the battery compartment . As far as I’m aware LR didn’t put relays in there so much be something aftermarket. More investigations required I think |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 226 ![]() ![]() ![]() |
Have you got towing equipment fitted, with a 13 pin socket. I’m sure the green/white is used to trigger the relay, to give a 12v switch live to the tow socket. I may be totally wrong, but worth a look,
Ashby Andy 👍🤔 |
