![]() | Home > Technical > What’s this connector for? |
Weston18 Member Since: 20 Oct 2013 Location: Norhamptonshire Posts: 100 ![]() ![]() ![]() |
Situated in the passenger compartment fuse box in a ‘02 TD5. Any advice?
Also have a few other plugs that are disconnected. Trying to diagnose the A/c not working at the minute. ![]() Click image to enlarge |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 208 ![]() ![]() ![]() |
It's not one I recognise and it's not the bulkhead loom to A/C one.
You can see all 2002 connectors here https://www.lrworkshop.com/connectors/defender-2002my And here you can search connectors by wire colour https://www.lrworkshop.com/connectors/defender-2002my/colour What are all the wire colours going into that connector? LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6656 ![]() ![]() ![]() |
I can't find it on the wiring diagrams either, but it appears to be on the AC controls side of the AC wiring.
You can see the blue/black + white/green + black/grey + brown going off on the other branch behind the fuse box, this should be going to the brown connector C0277 connecting to C0786 mounted on the fuse box plate. What are the wire colours, is it a 3 pin plug? ![]() ![]() |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
A question regarding this connector was raised on LR4x4 10 years ago -
https://lr4x4.com/topic/93404-td5-connector-conundrum/ There was no definitive answer as to what it was for - but Mo Murphy (the OP) traced the wires back into the harness and determined where they were fed from. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Thanks for the replies. Great knowledge.
My A/c investigation is still on going. Currently have no blower at all on the A/c, I think I’ve located the blower relay, just left of the blower controls? I’ll check voltage there. When I turn the blue dial I hear the engine note change, so something is happening there. Should the blower work regardless of blue dial position? Thanks all |
