Home > Tdi > 200tdi Timing Belt Running Off
mini Anaconda
I would like some advice regarding my timing belt running off. The belt seems to be running at a angle across the tensioner and rubbing on the retaining lip on the back of the tensioner pulley and starting to shred the belt.
A Dayco OEM belt kit along with a 2nd hand timing case was fitted 500 miles ago. (200tdi Discovery engine)
Does anyone have any recommendations or ideas on how to remedy the situation?
 BORG - Bucks & Oxon 4x4 Response Group
Post #1062225 6th Mar 2025 8:36pm
jst
Why the new timing case?
Did it do it before the new case?
There was an issue with sme tgv/300tdi with rear case.bending and belts running off, a support bracket was added back of fip.
Fit a shouldered pulley see if that helps.
Something is distorted so it's not running true, put a flat edge on it all?
Or a pulley is not fitted square. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1062230 6th Mar 2025 9:06pm
mini Anaconda
Short version of a long story, I put it in a garage for a cambelt and it came back with diesel leaking into the timing case. We have ended up trying to put their work right. Had the pump fixed, went to change the timing belt and the thread for the idler pulled out of the timing case. Replaced the case with one from Turners. I will have to presume the original belt was OK.
I can't see how the crank or cam gear can be incorrect. The injection pump has a gasket and the rear bracket, I also can't see how these can be fitted incorrectly.
Could the case actually still be warped in some way?
The cam gear, crank gear and pump gear seem to be inlline but I will double check. BORG - Bucks & Oxon 4x4 Response Group
Post #1062248 7th Mar 2025 6:25am
spudfan
Ireland
Definately looks out of kilter. Perhaps the basics were not adherred, like the double tensioning procedure. I have put the workshop manual pages here but I presume you have this info.
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1063300 18th Mar 2025 8:45pm
