Home > Puma (Tdci) > CheckTemp II Sensors |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Guys
Anyone found an innovative mounting for either the internal or external CheckTemp II sensors? I have read alantd's and dgardel's excellent reports. Thanks guys. Also AndrewS and Cobs's routing of the sensors (I'll probably use AndrewS's internal recommendations), was thinking of routing the external sensor into the chassis somewhere (maybe in the plastic cover under teh battery?), and the internal one into a door pillar. At the moment my CheckTemp is installed & working in every way except the 2 sensors...Just wondered if anyone had any new thoughts or experiences? Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
5th Dec 2011 1:30pm |
KPNuts Member Since: 21 Jan 2011 Location: Near Bedford Posts: 45 |
It will partly depend where you have put the display. I put my in the "pen tray" in the centre of the dash.
Internal sensor went on the blank centre switch low on the dash, but not ideal as heat coming from the low down outlets causes it to read high. External sensor went between inner wheel arch and the front of the wing on nearside (IIRC similar to dgardel's). Seems pretty accurate as does not seem to get engine or exhaust heat and is out of the wind. Wire was taken through bulkhead when running wiring for supplementary switches etc. 2010 110 Utility Station Wagon 1996 110 Station Wagon |
5th Dec 2011 5:15pm |
Thanks - I put my sensor in the "usual" place...but a bit higher than on alantd's piccie: Click image to enlarge I like the idea of putting the sensor on one of the blank switches in the dash.
I'll have a look at these sites, when the weather gets a bit better...getting numb fingers in about 3 mins at the moment! Thanks gents Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
6th Dec 2011 8:53am |
Andreas Schuback Member Since: 25 Oct 2011 Location: scotland Posts: 31 |
Martin, can you tell me where you get the temp gauge from looks smart!! cheers andreas.
6th Dec 2011 8:37pm |
6th Dec 2011 8:38pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
I got mine from Conrad.
http://shop.conrad-uk.com/car/car-equipmen...54714.html Bob |
6th Dec 2011 8:41pm |
SWEET cheers bob.
6th Dec 2011 8:43pm |
