Home > Puma (Tdci) > CheckTemp II Sensors
MartinK
Guys
Anyone found an innovative mounting for either the internal or external CheckTemp II sensors?
I have read alantd's and dgardel's excellent reports. Thumbs Up Thanks guys. Also AndrewS and Cobs's routing of the sensors (I'll probably use AndrewS's internal recommendations),
was thinking of routing the external sensor into the chassis somewhere (maybe in the plastic cover under teh battery?), and the internal one into a door pillar.
At the moment my CheckTemp is installed & working in every way except the 2 sensors...Just wondered if anyone had any new thoughts or experiences?
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #104714 5th Dec 2011 2:30pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
I ended up moving my external sensor as it was being affected by engine bay temperatures (it was in the inner wing) now relocated to just behind the headlight - seems fine so far.
The internal one'sat the back of the cubby box at the moment - I think from memory that dgardel has his on the dash which might be a better position
Post #104769 5th Dec 2011 6:10pm
KPNuts
England 2010 Defender 110 Puma 2.4 USW Alpine White
It will partly depend where you have put the display. I put my in the "pen tray" in the centre of the dash.
Internal sensor went on the blank centre switch low on the dash, but not ideal as heat coming from the low down outlets causes it to read high.
External sensor went between inner wheel arch and the front of the wing on nearside (IIRC similar to dgardel's). Seems pretty accurate as does not seem to get engine or exhaust heat and is out of the wind. Wire was taken through bulkhead when running wiring for supplementary switches etc. 2010 110 Utility Station Wagon
1996 110 Station Wagon
Post #104772 5th Dec 2011 6:15pm
MartinK
Thanks - I put my sensor in the "usual" place...but a bit higher than on alantd's piccie:
I like the idea of putting the sensor on one of the blank switches in the dash.
I'll have a look at these sites, when the weather gets a bit better...getting numb fingers in about 3 mins at the moment!
Thanks gents Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #104952 6th Dec 2011 9:53am
Andreas Schuback
Martin, can you tell me where you get the temp gauge from looks smart!! cheers andreas.
Post #105146 6th Dec 2011 9:37pm
Andreas Schuback
Post #105147 6th Dec 2011 9:38pm
bob neville
Post #105150 6th Dec 2011 9:41pm
Andreas Schuback
SWEET cheers bob.
Post #105151 6th Dec 2011 9:43pm
