![]() | Home > Puma (Tdci) > Egr fault |
Peterd Member Since: 17 Jan 2025 Location: Chichester Posts: 10 ![]() ![]() ![]() |
Just to add the new Egr valve and cooler was fitted and run before the HG was changed. It didn’t throw any faults.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 687 ![]() ![]() |
id start by going round the engine and disconnecting all the sensor / actuator connectors. maybe even check the codes as you do it..clear and retry at each one..many will share the 5v supply and ground and a fault on the wiring on one could pull others down...if you haven't already done this..
Thanks. I will have a look at all of the connections.
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 202 ![]() ![]() ![]() |
Follow the harness through the engine compartment and see if it is trapped, damaged, rubbing, etc.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
Have you plugged in the 6-pin throttle body connector, easily missed?
The P0487 code relates to the throttle body. ![]() ![]() |
Completely missed the throttle body. Many thanks . You are a lifesaver. All faults cleared.
