Home > Maintenance & Modifications > Double cab to Station wagon
Page 2 of 2 <12
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Here's some pics with connectors of a 2002-06 rear loom
https://www.lrworkshop.com/wiring-looms/de...not-pickup
It's for a 300Tdi not a Td5, so the only difference will be the fuel pump wiring LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1060973 20th Feb 2025 11:00am
rustandoil
Blimey...that's handy (and I dont even need that at the moment) thanks Will Thumbs Up
Post #1060974 20th Feb 2025 11:52am
maddad
United Kingdom 2001 Defender 110 Td5 DCPU Epsom Green
All your wiring specs were spot on with colours etc. Thumbs Up
But I missed one out. Theres a purple one in the flexi trunking with a bullet connector.
Post #1060975 20th Feb 2025 11:53am
maddad
So sorted the rear sides out.
Cut the outer edge off the door seal trim, see previous picture, filled the holes.
Just needs a bit of tiger seal to fill the gap. Makes it the sane length as a later defender side.
Will look fine after painting.
Post #1060976 20th Feb 2025 12:08pm
Martin
Site Admin
Purple bullet is permanent battery supply, doesn't connect to rear door.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1060977 20th Feb 2025 12:40pm
maddad
Dry day. Lift roof, remove sides and fit new side support bracket.
Bit of tiger seal on the door seal mounting too.
Post #1061036 21st Feb 2025 5:30pm
maddad
Some unexpected extra things.
Needed new safari corner cappings as originals had holes for drop down tailgate and had been modified for a swing out tail gate. So hinge holes were in the wrong place.
Plus no support brackets for rear door strut on the wheel arch.
YRM metals have been brilliant.
New rear door turned from sp4x4
Post #1061664 1st Mar 2025 1:41pm
maddad
Been a bit distracted by other projects.
But Alucab roof picked up and fitted.
Ready to go to paint shop.
Post #1063072 16th Mar 2025 2:38pm
maddad
Looking into wiring. There a few unused wires behind the auxiliary socket panel on the dash, early td5 dash. These must be for the rear wiper, wash etc
Making a new double din console for radio/gps
Post #1063073 16th Mar 2025 2:41pm
maddad
So the new Alucab roof is excellent, but when it rains the water runs off the gutter and dribbles down over the door.
Designed a 3D printed gutter extension to direct it on the front screen.
And some covers to tidy up the B pillar top bolts.
Post #1064401 1st Apr 2025 11:11am
maddad
Whilst in 3D print mode, made a new console for an Android double DIN radio, GPS, media player.
Including reversing camera
Post #1064402 1st Apr 2025 11:15am
maddad
Perhaps admin can change this thread title to Double cab to Station wagon to Camper Smile
Post #1064404 1st Apr 2025 11:22am
Page 2 of 2 <12
