![]() | Home > Maintenance & Modifications > Double cab to Station wagon |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 197 ![]() ![]() ![]() |
Here's some pics with connectors of a 2002-06 rear loom
https://www.lrworkshop.com/wiring-looms/de...not-pickup It's for a 300Tdi not a Td5, so the only difference will be the fuel pump wiring LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 785 ![]() ![]() ![]() |
Blimey...that handy (and I dont enven need that at the moment) thanks Will
![]() Last edited by rustandoil on 20th Feb 2025 11:21am. Edited 1 time in total |
maddad Member Since: 06 Feb 2025 Location: Sussex Posts: 15 ![]() ![]() ![]() |
So sorted the rear sides out.
Cut the outer edge off the door seal trim, see previous picture, filled the holes. ![]() Click image to enlarge Just needs a bit of tiger seal to fill the gap. Makes it the sane length as a later defender side. Will look fine after painting. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Purple bullet is permanent battery supply, doesn't connect to rear door.
Dry day. Lift roof, remove sides and fit new side support bracket.
![]() Click image to enlarge ![]() Click image to enlarge Bit of tiger seal on the door seal mounting too. ![]() Click image to enlarge |
