![]() | Home > Maintenance & Modifications > Double cab to Station wagon |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 208 ![]() ![]() ![]() |
Here's some pics with connectors of a 2002-06 rear loom
https://www.lrworkshop.com/wiring-looms/de...not-pickup It's for a 300Tdi not a Td5, so the only difference will be the fuel pump wiring LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 809 ![]() ![]() ![]() |
Blimey...that's handy (and I dont even need that at the moment) thanks Will
![]() Last edited by rustandoil on 17th Mar 2025 7:25am. Edited 2 times in total |
maddad Member Since: 06 Feb 2025 Location: Sussex Posts: 21 ![]() ![]() ![]() |
So sorted the rear sides out.
Cut the outer edge off the door seal trim, see previous picture, filled the holes. ![]() Click image to enlarge Just needs a bit of tiger seal to fill the gap. Makes it the sane length as a later defender side. Will look fine after painting. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6653 ![]() ![]() ![]() |
Purple bullet is permanent battery supply, doesn't connect to rear door.
Dry day. Lift roof, remove sides and fit new side support bracket.
![]() Click image to enlarge ![]() Click image to enlarge Bit of tiger seal on the door seal mounting too. ![]() Click image to enlarge |
Some unexpected extra things.
Needed new safari corner cappings as originals had holes for drop down tailgate and had been modified for a swing out tail gate. So hinge holes were in the wrong place. Plus no support brackets for rear door strut on the wheel arch. ![]() Click image to enlarge ![]() Click image to enlarge YRM metals have been brilliant. New rear door turned from sp4x4 ![]() Click image to enlarge |
Been a bit distracted by other projects.
But Alucab roof picked up and fitted. ![]() Click image to enlarge Ready to go to paint shop. |
Looking into wiring. There a few unused wires behind the auxiliary socket panel on the dash, early td5 dash. These must be for the rear wiper, wash etc
![]() Click image to enlarge Making a new double din console for radio/gps |
So the new Alucab roof is excellent, but when it rains the water runs off the gutter and dribbles down over the door.
Designed a 3D printed gutter extension to direct it on the front screen. ![]() Click image to enlarge And some covers to tidy up the B pillar top bolts. ![]() Click image to enlarge |
Whilst in 3D print mode, made a new console for an Android double DIN radio, GPS, media player.
![]() Click image to enlarge Including reversing camera ![]() Click image to enlarge |
Perhaps admin can change this thread title to Double cab to Station wagon to Camper
