Home > General & Technical (L663) > D250 remapping, where and was it flawless?
Page 3 of 3 <123
mse
haymeister wrote:
mse wrote:
Ill start by saying Ive never been into remapping cars,,
That negativity aside...from what i can see there are some different hardware configurations for factory looking through parts etc, theres things that arent applicable when you select the different engine power.
One thing that would worry me, the D300's were pulled due to higher than normal failures, so along side hardware i would be worried the d300 increases the chance of a failure.
Source for D300 having higher than normal failures?
They only sold the D300 here in Japan, then from last year with MY25 the D350. Have not heard about engine failures here.
the fact they discontinued them because of higher than normal failures Laughing Mike
Post #1062050 5th Mar 2025 10:00am
haymeister
Japan
I don't buy that.
They did it because they get better margins since it's mainly software.
D300 already has the beefier brakes, additional aux radiator, and perhaps other parts tuned for the higher load. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1062054 5th Mar 2025 10:27am
mse
it was increase failures - sorry
Its not always a simple matter of a radiator makes that configuration work etc. Mike
Post #1062063 5th Mar 2025 12:22pm
ruben
Spain
Well, I don't think anyone will ever sell you five pounds for a pound!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1062065 5th Mar 2025 12:49pm
lrFFM
Germany 2016 Defender 90 Puma 2.2 SW Keswick Green
Never read such nonsense. The D300 was not discontinued. It is still available in many markets.
Post #1062067 5th Mar 2025 1:17pm
lightning
l think the rumour stems from this thread about the D300.
https://www.defender2.net/forum/topic91314...e+failures
Post #1062069 5th Mar 2025 2:03pm
mse
D300 in some variants is but discontinued in the UK for the failure rate Mike
Post #1062074 5th Mar 2025 2:31pm
johnlad
Don’t know where your getting the information regarding the D300 being discontinued as Hendy group have just offered me a 25 plate Defender 110 X-Dynamic SE
D300
Post #1062105 5th Mar 2025 7:39pm
lightning
lt may have been discontinued temporarily while they charged people extra for the D350 which costs no more to make.
I ordered a D200 but then it was "discontinued" and l had to have the D250 at £3,000 more. But a few months after l took delivery, the D200 was once again available to order.
Post #1062116 5th Mar 2025 8:51pm
L3785
D300
The D300 isn’t available in the UK currently - you’ll want to check the build year of that model as there are still MY24 vehicles for sale as brand new (when the D300 was available). You’ll probably find that this vehicle is a MY24 year that hadn’t yet been registered - check the central console in the interior and that’ll be the biggest giveaway. 2025MY Defender 90 D250 X-Dynamic HSE | Santorini Black with Black Pack
Post #1062125 5th Mar 2025 9:30pm
mse
D300 and d350 isnt any difference in price.
But there are differences so its missleading to say its just a different engine map.
That said - basically what all electric vehicles do and all manufactures have done.
Plus theres a warranty cover thats priceless! Mike
Post #1062159 6th Mar 2025 9:44am
BadgerWaz
TTW in nottingham use the pathfinder interface and oem software for the remap. LR were too greedy to offer the hardtop with the same power as the car, though the engines are the same.
When manufacturers have recalls due to poor mapping it's often due to overheating issues/carbonisation from lean fuelling. This gets revised with later recalls.
The D300 still sells. The larger brake calipers/discs on the D300 are un-neccessary on a van, and would take me half a day to change all four if I felt inclined.
To upgrade the D250 to D300 requires no physical changes to the engine at all. For example:
fuel pump, turbo, wastegate, intercooler, fuel rails, injectors, fuel pressure sensors, lambda sensors, induction air etc. etc. are not needed. The stock ones are adequate.
The software is loaded via the OBD port and removal of the ecu isn't required. From my experience this shows the upgrade is straightforward and I'm confident it is actually LR files uploaded. TTW have confirmed this is the case also.
The defender isn't a race car, it's a tractor designed to pull. Adding 50hp to a modern six-cylinder diesel won't melt it. The benefit for me with more torque is the ability to get a quicker shift-on when the trailer is on the back when driving through the wolds fully-laden. Also being LR software any warranty work couldn't be refused. Consumables like brakes aren't covered anyway and are cheap enough to replace, but if you tried to race a defender on the open road and slam-on at the very last minute you're clearly driving like a plonker and are in the wrong car to start off with.
If my engine fails, you can say 'you told me so.'
But it won't.
Thanks for the input everyone. Power is always a talking point regardless of the marque.
Post #1062368 8th Mar 2025 1:27pm
Page 3 of 3 <123
