Home > Technical > Defender 90 2015 GKN OEM rear prop shaft UJ
Marty008
Switzerland 2015 Defender 90 Puma 2.2 CSW Santorini Black
Hello guys,
Any idea to further proceed with the removal of the union - I can’t get it out, the needles cage are longer, and stay within the flange…. Shall I try to cut them?!
Tank you for your support.
Regards
Post #1059227 2nd Feb 2025 2:14am
Oldowner
I have cut them in the past
Post #1059231 2nd Feb 2025 8:21am
Grip the protruding cup in a vice and drift the flange off it. Drift the other cup back the other way and repeat, then repeat the whole process on the shaft.
Be very careful reassembling the joint since if you drop a roller you almost certainly won't be able to remove the joint without damage.
Post #1059250 2nd Feb 2025 10:29am
Marty008
Thank you it is exactly what I have done - it does worked out 💪🏼!!!
Keep you posted with re-assembly!
Post #1059258 2nd Feb 2025 11:12am
