![]() | Home > Technical > Defender 90 2015 GKN OEM rear prop shaft UJ |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 643 ![]() ![]() ![]() |
I have cut them in the past
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17691 ![]() ![]() ![]() |
Grip the protruding cup in a vice and drift the flange off it. Drift the other cup back the other way and repeat, then repeat the whole process on the shaft.
Be very careful reassembling the joint since if you drop a roller you almost certainly won't be able to remove the joint without damage. |
Marty008 Member Since: 10 Jun 2024 Location: Luzern Posts: 10 ![]() ![]() ![]() |
Thank you it is exactly what I have done - it does worked out 💪🏼!!!
Keep you posted with re-assembly! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
