![]() | Home > Maintenance & Modifications > Oil pickup pipe |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
According to the (genuine) WSM:
It is however not a routine service item, it is a screen not a filter. |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 332 ![]() ![]() ![]() |
I recently had my sump off on my Puma 2.4, and when I checked the pickup, it had some "gunk" on the mesh. I took it off and cleaned it out. To me it looked like it would hinder the oil flow, so hopefully will be better now. Not started the engine since the clean.
Phillywilly72 Member Since: 29 Apr 2024 Location: Wiltshire Posts: 72 ![]() ![]() ![]() |
Exactly my thoughts as the tdci has an issue with burning out pistons due to lack of oil cooling.
cretesimon Member Since: 01 Nov 2021 Location: heraklon Posts: 56 ![]() ![]() |
Have also seen two of the 2.4 tdci pick ups for the oil pump cracked at the joint where glued together
Interesting that the WSM refers to a fabricated steel pick up but all the pictures seem to show a plastic one.
Yet another error with the WSM I suspect. |
Beco90 Member Since: 10 Jul 2024 Location: South Wales Posts: 20 ![]() ![]() |
There was a technical article in the last issue of Land Rover Monthly (Feb 2025) on how to replace the oil pickup pipe on a 2.4 TDCI if that would be helpful? The photos showed a plastic pick up.
