Home > Maintenance & Modifications > Oil pickup pipe
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Oil pickup pipe
Can anyone tell me if the pickup sump pipe or oil pump have filters built in? If they do should these be replaced as part of the servicing schedule? Thanks
Post #1058801 28th Jan 2025 3:31pm
According to the (genuine) WSM:
The WSM wrote:
The fabricated steel oil pick-up is immersed in the oil reservoir to provide a supply to the oil pump during all normal vehicle attitudes. A mesh screen in the inlet prevents debris from entering the oil system.
It is however not a routine service item, it is a screen not a filter.
Post #1058814 28th Jan 2025 7:13pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
I recently had my sump off on my Puma 2.4, and when I checked the pickup, it had some "gunk" on the mesh. I took it off and cleaned it out. To me it looked like it would hinder the oil flow, so hopefully will be better now. Not started the engine since the clean.
Post #1058859 29th Jan 2025 10:16am
Phillywilly72
Exactly my thoughts as the tdci has an issue with burning out pistons due to lack of oil cooling.
Post #1058862 29th Jan 2025 10:50am
cretesimon
Greece
Have also seen two of the 2.4 tdci pick ups for the oil pump cracked at the joint where glued together
Post #1058872 29th Jan 2025 1:38pm
Interesting that the WSM refers to a fabricated steel pick up but all the pictures seem to show a plastic one.
Yet another error with the WSM I suspect.
Post #1058908 29th Jan 2025 7:08pm
Beco90
There was a technical article in the last issue of Land Rover Monthly (Feb 2025) on how to replace the oil pickup pipe on a 2.4 TDCI if that would be helpful? The photos showed a plastic pick up.
Post #1058950 30th Jan 2025 8:03am
