![]() | Home > BMW Engine Conversions > 2.4 Puma to M57 6HP auto Conversion difflock retention? |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 196 ![]() ![]() ![]() |
Anyone had a conversion done and successfully kept high, low and diff lock?
Had my conversion done by a garage who just merely fitted a high and low range lever. This a cop out by them or is there genuine issues? I’ve seen a mechanical kit and air engaged ones. Cheers |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8186 ![]() ![]() ![]() |
There is a relocation bracket that blackbird 4x4? Do james ayre makes them, believe that does both.
I have Marcus's Air operated setup. Diff lock actuation works very well, used about 6 to 8 times a day 3 days a week since Sept and no problems. I already had onboard Air. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2307 ![]() ![]() ![]() |
I used a disco cable shifter for hi /lo and vacuum operation for the diff lock. Works very well.
🤔 ok…
They fitted the cable disco shifter for high and low. I was spun a line that the “air locker” for diff lock wasn’t reliable so they never fitted it despite being on quote. Got a problem with heater blowing in exhaust fumes when not on recirculation too which needs addressing. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1843 ![]() ![]() ![]() |
So thats a big discount towards an Ashcroft LSD then !!
