![]() | Home > Puma (Tdci) > Windscreen washer pump electrical connectors |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
I can recall from when I reworked my screen washers and fitted headlight washers that they weren't easy to find, but the info is already here somewhere on the forum.
Update - after some careful use of the search function I am reminded that they are Econoseal 250 Series connectors, and I sourced mine from Simtek. See https://www.defender2.net/forum/topic58137-15.html? Last edited by blackwolf on 19th Jan 2025 10:00pm. Edited 2 times in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
The following link might be helpful to research further:
https://www.lrworkshop.com/connectors/defender-1999/C0008 On the RHS you can choose different year details. Somewhere like 3 Way Components, Durite or similar supplier might well do the parts you are looking for if you can identify the exact type and size. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2246 ![]() ![]() |
Brilliant, thanks Blackwolf
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
The front washer pump connector C0008 is an Econoseal III 070 (1.8mm) Red 2-way female connector.
You won't find a mating male connector in Red - but, all colours are keyed the same, so a standard Black 2-way male connector will mate with C0008 They're available from numerous sellers, including 3waycomponents, Polevolt, etc... https://www.3waycomponents.co.uk/product/2...ector-kit/ https://polevolt.co.uk/2w-econoseal-connec...-973-p.asp . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
