Home > Puma (Tdci) > Windscreen washer pump electrical connectors |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17516 |
I can recall from when I reworked my screen washers and fitted headlight washers that they weren't easy to find, but the info is already here somewhere on the forum.
Update - after some careful use of the search function I am reminded that they are Econoseal 250 Series connectors, and I sourced mine from Simtek. See https://www.defender2.net/forum/topic58137-15.html? Last edited by blackwolf on 19th Jan 2025 9:00pm. Edited 2 times in total |
19th Jan 2025 8:32pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20549 |
The following link might be helpful to research further:
https://www.lrworkshop.com/connectors/defender-1999/C0008 On the RHS you can choose different year details. Somewhere like 3 Way Components, Durite or similar supplier might well do the parts you are looking for if you can identify the exact type and size. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
19th Jan 2025 8:49pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2092 |
Brilliant, thanks Blackwolf
19th Jan 2025 9:30pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 503 |
The front washer pump connector C0008 is an Econoseal III 070 (1.8mm) Red 2-way female connector.
You won't find a mating male connector in Red - but, all colours are keyed the same, so a standard Black 2-way male connector will mate with C0008 They're available from numerous sellers, including 3waycomponents, Polevolt, etc... https://www.3waycomponents.co.uk/product/2...ector-kit/ https://polevolt.co.uk/2w-econoseal-connec...-973-p.asp . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
20th Jan 2025 2:23pm |
