Home > Puma (Tdci) > Windscreen washer pump electrical connectors
Ianh
I’m about to replace the windscreen washer pump with a more powerful one. As this draws more current than the standard one I’m going to provide a relay plus larger conductor wiring and higher rated fuse.
Rather than cutting wires I would like to use the existing connector, so does anyone know the part numbers for the male and female version of the connector. In the LR electrical connector library it’s connector C0008.
Ps if you also know where I can purchase the connectors that would be appreciated.
Post #1057900 19th Jan 2025 9:11pm
I can recall from when I reworked my screen washers and fitted headlight washers that they weren't easy to find, but the info is already here somewhere on the forum.
Update - after some careful use of the search function I am reminded that they are Econoseal 250 Series connectors, and I sourced mine from Simtek.
See https://www.defender2.net/forum/topic58137-15.html?
Post #1057902 19th Jan 2025 9:32pm
The following link might be helpful to research further:
https://www.lrworkshop.com/connectors/defender-1999/C0008
On the RHS you can choose different year details.
Somewhere like 3 Way Components, Durite or similar supplier might well do the parts you are looking for if you can identify the exact type and size. WeWillWin🇬🇧🇺🇸
Post #1057906 19th Jan 2025 9:49pm
Ianh
Brilliant, thanks Blackwolf Thumbs Up
Post #1057916 19th Jan 2025 10:30pm
PaulMc
The front washer pump connector C0008 is an Econoseal III 070 (1.8mm) Red 2-way female connector.
You won't find a mating male connector in Red - but, all colours are keyed the same, so a standard Black 2-way male connector will mate with C0008
They're available from numerous sellers, including 3waycomponents, Polevolt, etc...
https://www.3waycomponents.co.uk/product/2...ector-kit/
https://polevolt.co.uk/2w-econoseal-connec...-973-p.asp
. Paul.
Post #1057989 20th Jan 2025 3:23pm
