![]() | Home > Modifications & Maintenance (L663) > Rock slider |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
Devon 4x4 have some really good looking and well made ones.
https://devon4x4.com/d44def2110ts-d44.html Eiger Grey MY23 D250 SE with bits. Known as Noddy. Last edited by Moo on 21st Jan 2025 11:34am. Edited 1 time in total |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 664 ![]() ![]() |
Personally, if they get used often, I prefer galvanized ones, so they don’t rust as soon as you start to pick up bangs, scrapes etc. However, there’s none available for L663 that are galvanized.
The terrafirma ones are available for both 110 & 90. They fit well, good enough design that is relatively easy to fit (about 90 minutes per side). Both the plastic and felt like material underbody guards will need cutting and on one side you need to drill a new hole (it’s already there on one side) for a rear bracket. On the ones that shipped to us there were a few knocks in the paint, despite the good packaging, and these needed touching up with satin black before fitting. https://terrafirma4x4.com/media/fitting_ki...liders.pdf |
F-Typical Member Since: 05 Sep 2024 Location: Hereford Posts: 51 ![]() ![]() |
Granite generally makes the best rocks. Avoid sedimentary stuff as it crumbles too easily. ![]() |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 305 ![]() ![]() |
and those of chemical origin such as carbonates also dilute with water!! 🤭 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1434 ![]() ![]() ![]() |
I would love a set of Tuffant Rock Sliders but I can only get them via the USA or Australia, but the carriage charge is a little excessive
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
