Home > Modifications & Maintenance (L663) > Rock slider
Crazymind
Rock slider
Hi folks, planning to add rock sliders. I don’t have much experience with rocks… what should I look for? Any brand suggestions?
Post #1057821 19th Jan 2025 10:29am
Moo
Ukraine
Devon 4x4 have some really good looking and well made ones.
https://devon4x4.com/d44def2110ts-d44.html Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1057824 19th Jan 2025 11:12am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Personally, if they get used often, I prefer galvanized ones, so they don’t rust as soon as you start to pick up bangs, scrapes etc. However, there’s none available for L663 that are galvanized.
The terrafirma ones are available for both 110 & 90. They fit well, good enough design that is relatively easy to fit (about 90 minutes per side). Both the plastic and felt like material underbody guards will need cutting and on one side you need to drill a new hole (it’s already there on one side) for a rear bracket.
On the ones that shipped to us there were a few knocks in the paint, despite the good packaging, and these needed touching up with satin black before fitting.
https://terrafirma4x4.com/media/fitting_ki...liders.pdf
Post #1057842 19th Jan 2025 1:38pm
F-Typical
Re: Rock slider
Granite generally makes the best rocks. Avoid sedimentary stuff as it crumbles too easily. Smile
Post #1058040 20th Jan 2025 8:47pm
ruben
Spain
and those of chemical origin such as carbonates also dilute with water!! 🤭 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1058076 20th Jan 2025 11:00pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I would love a set of Tuffant Rock Sliders but I can only get them via the USA or Australia, but the carriage charge is a little excessive Crying or Very sad Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1058085 21st Jan 2025 12:32am
