mptzs90 wrote:There’s no rattle when I’m stationary,
That is not what I asked!
Does the rattle stop if (a) you are moving, (b) you are rattling, and (c) you apply the brakes?
If so, it will be the brake bads. If not, it won't be the brake pads!
21st Jan 2025 9:45am |
mptzs90
Quote:Given it’s not constant - I think the way to test that is rolling down a hill… assuming it will rattle; and then light pressure to the brakes to see if it stops?
Assuming this is a reasonable test... unfortunately no difference. I think next step is to start removing trim from the rear to ensure it's not something knocking/rubbing the body.
21st Jan 2025 10:44am |
