Home > Puma (Tdci) > Rattle behind/under drivers seat
Page 3 of 3 <123
mptzs90
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
There’s no rattle when I’m stationary, so yes. Sounds like another thing worth checking! Might see if i can record it happening in case that helps identify. Best description i can think of is like a stone/metal on a metal panel rather than anything heavy.
Thanks!
Post #1058068 20th Jan 2025 10:21pm
That is not what I asked!
Does the rattle stop if (a) you are moving, (b) you are rattling, and (c) you apply the brakes?
If so, it will be the brake bads. If not, it won't be the brake pads!
Post #1058098 21st Jan 2025 9:45am
mptzs90
Given it’s not constant - I think the way to test that is rolling down a hill… assuming it will rattle; and then light pressure to the brakes to see if it stops?
Post #1058099 21st Jan 2025 9:48am
mptzs90
Assuming this is a reasonable test... unfortunately no difference. I think next step is to start removing trim from the rear to ensure it's not something knocking/rubbing the body.
Post #1058105 21st Jan 2025 10:44am
Page 3 of 3 <123
