Home > Technical > Washers used for Alive Comfort Shocks
WestCountryPete
I’m just fitting Alive Comfort Bilstein dampers on my 110 (Puma) and looking for a bit of guidance from anyone that’s fitted some. On the rears, what washers/spacers are people using on the original LR mounts?
The top bushings on the shocks are already mounted on a metal tube that’s wider than the rubber and eye. Be good to hear what others have done.
Thanks all in advance.
Post #1057102 11th Jan 2025 10:50pm
PoormansXS
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Hi, sorry I’m no help for your problem but once you have fitted/tested the shocks could you let me know what you think of them? I’m tempted to go for a set with the -1 springs
Post #1057155 12th Jan 2025 3:09pm
MK
Not sure I understand but I would follow a per LR instructions. The 2 upper washers are not identical and their curved/convex side face towards the bushing. Puma 110" SW
Post #1057168 12th Jan 2025 4:44pm
Elliskwleisk
United Kingdom 2003 Defender 110 Td5 XS DCPU Java Black
Hey Pete, I’m not far from you in the southwest. May I ask your thoughts on the Alive Comfort Dampers - are they worth the extra money? Considering the set up for my 110. Thanks
Post #1061156 23rd Feb 2025 6:09pm
WestCountryPete
I’ve done the backs which appear good, but haven’t managed to fit the fronts yet, so can’t be 100%. The old dampers were also terrafirma and knackered, so probably not a fair comparison Laughing
When I finally get the fronts done, I’ll report back on here. Injector seals are at the top of my list first though….never ending, isn’t it Rolling Eyes
Post #1061909 3rd Mar 2025 10:49pm
