Home > Technical > Washers used for Alive Comfort Shocks
WestCountryPete
I’m just fitting Alive Comfort Bilstein dampers on my 110 (Puma) and looking for a bit of guidance from anyone that’s fitted some. On the rears, what washers/spacers are people using on the original LR mounts?
The top bushings on the shocks are already mounted on a metal tube that’s wider than the rubber and eye. Be good to hear what others have done.
Thanks all in advance.
Post #1057102 11th Jan 2025 9:50pm
PoormansXS
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Hi, sorry I’m no help for your problem but once you have fitted/tested the shocks could you let me know what you think of them? I’m tempted to go for a set with the -1 springs
Post #1057155 12th Jan 2025 2:09pm
MK
Not sure I understand but I would follow a per LR instructions. The 2 upper washers are not identical and their curved/convex side face towards the bushing. Puma 110" SW
Post #1057168 12th Jan 2025 3:44pm
