![]() | Home > Technical > Washers used for Alive Comfort Shocks |
PoormansXS Member Since: 21 Oct 2023 Location: Lincolnshire Posts: 56 ![]() ![]() ![]() |
Hi, sorry I’m no help for your problem but once you have fitted/tested the shocks could you let me know what you think of them? I’m tempted to go for a set with the -1 springs
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
Not sure I understand but I would follow a per LR instructions. The 2 upper washers are not identical and their curved/convex side face towards the bushing. Puma 110" SW
Elliskwleisk Member Since: 22 Mar 2019 Location: SWE Posts: 4 ![]() ![]() ![]() |
Hey Pete, I’m not far from you in the southwest. May I ask your thoughts on the Alive Comfort Dampers - are they worth the extra money? Considering the set up for my 110. Thanks
WestCountryPete Member Since: 30 Sep 2023 Location: Wiltshire Posts: 43 ![]() ![]() ![]() |
I’ve done the backs which appear good, but haven’t managed to fit the fronts yet, so can’t be 100%. The old dampers were also terrafirma and knackered, so probably not a fair comparison
![]() When I finally get the fronts done, I’ll report back on here. Injector seals are at the top of my list first though….never ending, isn’t it ![]() |
