![]() | Home > Puma (Tdci) > Diff Clunk! |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 202 ![]() ![]() ![]() |
I bought the car with 101K kms on it. It had a clunk and a "too much freeplay", vibratory howl on/off throttle at speed. I drive in extreme winter conditions so I fit 3 ATB diffs (front/rear/centre), new clutch, and a LOF adapter shaft. I also replaced all from axle flanges with heavy duty ones and fit uprated rear shafts.
The clunk is gone and the vibratory howl is 99.9% gone. Dunno what the culprit was as I did the work for other reasons. |
Landowner Member Since: 06 Jan 2023 Location: Somerset Posts: 78 ![]() ![]() ![]() |
Definitely the rear diff. 2-pin diffs famous for it, Pinions wearing an oval their housing.Dangerous if left, can lock the diff as speed.
Ah, very true, I missed that point.
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 648 ![]() ![]() ![]() |
Also likely to be wear in the carrier from the planetary gears imbedding themselves into the carrier as I don’t think the budget 4pin rear has thrust washers - it doesn’t take too much prolonged wheelspin to start wearing the carrier which is the usual cause of wear related clunk from the diff centre itself. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
Wheelspin then suddenly gaining traction, is a good way of busting a halfshaft too. WeWillWin🇬🇧🇺🇸
