Home > Puma (Tdci) > PUMA Airconditioning problem |
Defderico Member Since: 11 Dec 2020 Location: New Caledonia Posts: 17 |
Hi there
I have no aircondtioning in my 110 TDCI 2011. It was good untill I stock the truck for some months due to a gearbox clutch changed The switch has the light on The relay is working Fuse is ok But the clutch do not engaged Gaz sound when I push on the valve I look at the connector on the compressor to see if there is voltage when the incab switch is on : nothing What should be the voltage : 12 V ? Any advice will be very appreciate as the summer is already here Thanks, cheers May 2025 be a better year |
31st Dec 2024 12:00am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Probably needs a regas Instagram @defender_ventures
Empire Tuning - Agent |
31st Dec 2024 10:19am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1104 |
Did you check the pressure with a cheap Harborfreight AC gauge set? Oh no it's Europe, where you need an expert for everything and "right to repair" is just a popular catch phrase.
No compressor engagement typically means the gas pressure has dropped too low, caused by a leak in the system |
31st Dec 2024 2:14pm |
Very angry about that We can buy AC Pro aircon gauges and refills which is what I use Instagram @defender_ventures
31st Dec 2024 2:24pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3340 |
You can buy it in Europe too but itโs also illegal to refill fluorinated gas without proper qualifications in this country. WARNING.
This post may contain sarcasm. |
31st Dec 2024 3:11pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1796 |
Well at least I know where New Caledonia is now.......
Local LeClerc does a refill offer a couple of times a year, โฌ45 and an hours wait, job done! |
31st Dec 2024 3:20pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17505 |
Most UK a/c gas is no longer fluorinated, and the DIY type canisters certainly aren't.
31st Dec 2024 3:50pm |
