![]() | Home > Puma (Tdci) > PUMA Airconditioning problem |
Defderico Member Since: 11 Dec 2020 Location: New Caledonia Posts: 17 ![]() ![]() ![]() |
Hi there
I have no aircondtioning in my 110 TDCI 2011. It was good untill I stock the truck for some months due to a gearbox clutch changed The switch has the light on The relay is working Fuse is ok But the clutch do not engaged Gaz sound when I push on the valve I look at the connector on the compressor to see if there is voltage when the incab switch is on : nothing What should be the voltage : 12 V ? Any advice will be very appreciate as the summer is already here Thanks, cheers May 2025 be a better year |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20661 ![]() ![]() |
It perhaps needs a re-gas. TheThunder Rolls🇬🇧🇺🇸
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2196 ![]() ![]() |
Probably needs a regas Instagram @defender_ventures
Empire Tuning - Agent |
Very angry about that
![]() ![]() Empire Tuning - Agent |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3351 ![]() ![]() ![]() |
You can buy it in Europe too but it’s also illegal to refill fluorinated gas without proper qualifications in this country. WARNING.
This post may contain sarcasm. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1838 ![]() ![]() ![]() |
Well at least I know where New Caledonia is now.......
Local LeClerc does a refill offer a couple of times a year, €45 and an hours wait, job done! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17628 ![]() ![]() ![]() |
Most UK a/c gas is no longer fluorinated, and the DIY type canisters certainly aren't.
